Announcements
Notice: Upload of PDF documents is currently unavailable across the Community due to an ongoing issue.
MASH deformer not working as expected
marcus
marcus
I'm having trouble getting the MASH deformer to work as shown in the tutorial on Mainframes website.
I' not able to get the scaling to be affected by noise. As far as I can tell, the scalePP is not going into the deformer.
could someone please try it and give me feedback if I'm missing something or if this is another bug?
regards
marcus
Nadja.Bueckmann
Hi @marcus,
can you send me a link to the tutorial you are referring to?
Best, Nadja
Nadja Bueckmann
Technical Support Specialist – M&E (3ds Max, Maya)
marcus
Hi Nadja,
of course
https://vimeo.com/83579056
before you say, this tutorial was for MASH 2.2.3,   I know that. but I tried to make sense of the manual and also tried to replicate the effect in the tutorial, and the scalePP is not automatically connected, when applying a noise to the scale attribute for the mash network.
Also, I believe I already submitted a bug report 😕
regards
Marcus
Nadja.Bueckmann
Hi @marcus,
no problem. I´ll have a look. I will also look if there is already an issue logged with our development deparment 😉
Best, Nadja
Nadja Bueckmann
Nadja.Bueckmann
Hi @marcus,
one more question: which version did you use? Maya 2016 Extension2 SP1?
Best, Nadja
Nadja Bueckmann
marcus
Hi, Nadja,
Yes, that is correct.
Maya 2016 EXT2 SP1
Nadja.Bueckmann
Hi @marcus,
I recreated the setup on my side.
As you already pointed out, I also experienced that face scaling on the deformer is not working as expected.
So I tried to find a workaround.
You can achieve the same effect very easily with the Explode node.
On the link below you can find a video walkthrough of using the Explode node in Ext 2.
MashDeformer
Hope that helps. Looking for your feedback,
Nadja
Nadja Bueckmann
