Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Main Poly Limit Exceeded??
3 REPLIES 3
2867 Views, 3 Replies
I have this warning come up on a scene I'm working on but not sure how its affecting it.
// Warning: Main poly limit exceeded: 150012 faces created out of 264144 - See Docs for reduction hints.
Is maya actually culling some of my geometry to conform to this 100,000 limit?? is there a way I can change this. I can still move about my scene at a reasonable frame rate (about 20fps).
Please help, i need every polygon in there!!!
3 REPLIES 3
I am having the same problem here!!!
Hi there, go to the option box in the modify>convert>paint fx to polygons and set the poly limit to 0 (that means no limit)and you should be fine.Save before doing it because it can be pretty heavy
enjoy
icephixia2000
Thanks man that worked!
