Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
List of Dockable places
5 REPLIES 5
2090 Views, 5 Replies
Hi all ,
I've been digging in to this for far too long and cant figure out how to list all my dockable locations in the maya UI.
When you show the Outliner , by default it docks to the Veiwport.  I cant figure out how to dock my custion UI into that spot.
I can show the Outliner or ChannalboxEditor and TabToControl my UI to the Outliner or ChannalboxEditor
I can TabToControl my UI to the Viewport.
I can dock to the left side of the main window .
but i cant dock to the side of the viewport.
Can anyone please help!.
this is the code Ive been using to test out UI.
I'm using MAYA 2018.3
import weakref
import maya.cmds as cmds
import maya.OpenMayaUI as omui
from shiboken2 import wrapInstance
from Qt_py.Qt import QtGui, QtWidgets, QtCore
def dock_window(dialog_class):
    try:
        cmds.deleteUI(dialog_class.CONTROL_NAME)
        logger.info('removed workspace {}'.format(dialog_class.CONTROL_NAME))
    except:
        pass
    # building the workspace control with maya.cmds
    main_control = cmds.workspaceControl(dialog_class.CONTROL_NAME, ttc=["Outliner", -1],iw=300, mw=True, wp='preferred', label = dialog_class.DOCK_LABEL_NAME)
    # now lets get a C++ pointer to it using OpenMaya
    control_widget = omui.MQtUtil.findControl(dialog_class.CONTROL_NAME)
    # conver the C++ pointer to Qt object we can use
    control_wrap = wrapInstance(long(control_widget), QtWidgets.QWidget)
    # control_wrap is the widget of the docking window and now we can start working with it:
    control_wrap.setAttribute(QtCore.Qt.WA_DeleteOnClose)
    win = dialog_class(control_wrap)
    # after maya is ready we should restore the window since it may not be visible
    cmds.evalDeferred(lambda *args: cmds.workspaceControl(main_control, e=True, rs=True))
    # will return the class of the dock content.
    return win.run()
class MyDockingUI(QtWidgets.QWidget):
    instances = list()
    CONTROL_NAME = 'my_workspcae_control'
    DOCK_LABEL_NAME = 'my workspcae control'
    def __init__(self, parent=None):
        super(MyDockingUI, self).__init__(parent)
        # let's keep track of our docks so we only have one at a time.
        MyDockingUI.delete_instances()
        self.__class__.instances.append(weakref.proxy(self))
        self.window_name = self.CONTROL_NAME
        self.ui = parent
        self.main_layout = parent.layout()
        self.main_layout.setContentsMargins(2, 2, 2, 2)
        # here we can start coding our UI
        self.my_label = QtWidgets.QLabel('hello world!')
        self.main_layout.addWidget(self.my_label)
    @staticmethod
    def delete_instances():
        for ins in MyDockingUI.instances:
            logger.info('Delete {}'.format(ins))
            try:
                ins.setParent(None)
                ins.deleteLater()
            except:
                # ignore the fact that the actual parent has already been deleted by Maya...
                pass
            MyDockingUI.instances.remove(ins)
            del ins
    def run(self):
        return self
# this is where we call the window
my_dock = dock_window(MyDockingUI)
cmds.workspaceControl("Outliner",edit=True, restore=True)
cmds.workspaceControl("ChannelBoxLayerEditor",edit=True, restore=True)
# COMMANDS TO MOVE WINDOW AROUND
#cmds.workspaceControl("my_workspcae_control",edit=True, tabToControl=( "Outliner" ,-1))
#cmds.workspaceControl("my_workspcae_control",edit=True, tabToControl=( 'MainPane' ,-1))
#cmds.workspaceControl("my_workspcae_control",edit=True, dockToMainWindow=( "left", True))
#cmds.workspaceControl("my_workspcae_control",edit=True, dockToPanel=( 'MainPane', 'left' ,-1))
#cmds.workspaceControl("my_workspcae_control",edit=True, tabToControl=( "ChannelBoxLayerEditor" ,-1))
5 REPLIES 5
A colleague of mine found these online
MAIN_WORKAREA = mel.eval('$gWorkAreaForm=$gWorkAreaForm')
MAIN_PANE = mel.eval('$gViewportWorkspaceControl=$gViewportWorkspaceControl')
CHAN_LAYER_EDITOR = mel.eval('getUIComponentDockControl("Channel Box / Layer Editor", false)')
OUTLINER = mel.eval('getUIComponentDockControl("Outliner", false)')
SHELF = mel.eval('getUIComponentToolBar("Shelf", false)')
TIME_SLIDER = mel.eval('getUIComponentToolBar("Time Slider", false)')
RANGE_SLIDER = mel.eval('getUIComponentToolBar("Range Slider", false)')
COMMAND_LINE = mel.eval('getUIComponentToolBar("Command Line", false)')
HELP_LINE = mel.eval('getUIComponentToolBar("Help Line", false)')
TOOL_BOX = mel.eval('getUIComponentToolBar("Tool Box", false)')
Does anyone know how to get the workspaceControl for UV Editor and the UV Toolkit ?
A List all command would be really nice.
Tags (3)
cheng_xi_li
You could find the workspaceNames in
scripts/others/texturePanelShow.mel and UVToolkitPanel.mel
I am afraid there isn't a command for listing all dockable areas.
Yours,
Li
in reply to: cheng_xi_li
Thanks for the insight . I was able to find the UI name in the mel script repository.
cmds.workspaceControl("my_workspcae_control",edit=True, tabToControl=( "UVToolkitDockControl" ,-1))
cmds.workspaceControl("my_workspcae_control",edit=True, tabToControl=( "polyTexturePlacementPanel1Window" ,-1))
Updated list
UI_DOCK_SPOTS = {
"CHAN_LAYER_EDITOR": mel.eval('getUIComponentDockControl("Channel Box / Layer Editor", false)'),
"OUTLINER": mel.eval('getUIComponentDockControl("Outliner", false)'),
"SHELF": mel.eval('getUIComponentToolBar("Shelf", false)'),
"TIME_SLIDER": mel.eval('getUIComponentToolBar("Time Slider", false)'),
"RANGE_SLIDER": mel.eval('getUIComponentToolBar("Range Slider", false)'),
"COMMAND_LINE": mel.eval('getUIComponentToolBar("Command Line", false)'),
"HELP_LINE": mel.eval('getUIComponentToolBar("Help Line", false)'),
"TOOL_BOX": mel.eval('getUIComponentToolBar("Tool Box", false)'),
"TOOL_SETTINGS": mel.eval('getUIComponentDockControl("Tool Settings", false)'),
"UV_EDITOR": "polyTexturePlacementPanel1Window",
"UV_TOOLKIT": "UVToolkitDockControl"
