Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
keying color of some nodes gives constant error/spam in script editor
2 REPLIES 2
nobody_b
421 Views, 2 Replies
I was making a light rig when I found that setting animation keys gave me a constant spamming error in the script editor (with echo all commands on). It spams:
timeField -edit -value `currentTime -query` TimeSlider|MainTimeSliderLayout|formLayout8|timeField1;
// Result: TimeSlider|MainTimeSliderLayout|formLayout8|timeField1 //
it slowed down Maya enough to make it unusable
I cut down the nodes to get the minimum amount of nodes necessary to reproduce the issue:
key the green channel of one of the colors of a blend color that's going into the color of a sky dome light
please take a look at the attached file
2 REPLIES 2
mspeer
in reply to: nobody_b
Hi!
Please report this problem (bug?) to Autodesk.
In Maya main menu:
Help -> Speak Back -> Report a Problem
(You can add a link to this thread, for the file.)
This bug is related to EM "Parallel".
As a workaround:
a) Switch Evaluation Mode from "Parallel" to "DG" (in Preferences > Settings > Animation > Evaluation).
b) You can also set Idle Action to anything else than "Idle Rebuild and Prepare for Manip" in Evaluation Toolkit -> 01)Modes -> ...
(Please add this information to the bug-report.)
marie-jeanne_leduc
in reply to: mspeer
Thank you for reporting this issue.
We can reproduce it and it has been logged as MAYA-112315.
Marie-Jeanne
Marie-Jeanne Leduc
Senior QA Analyst
