keep getting error messages autoLoadPlugin.mel line 35:,filePathEditorRegistryPrefs.mel line 4: filePathEditor: errors
Message 1 of 1
I keep getting errors no matter which version of maya uninstall and install, plus any character rigs i use, tend to break of have the channel box values disappear. the only version of maya that does not give me this error is 2014,
but i get the following error message in maya 2014...
// Warning: file: C:/Program Files/Autodesk/Maya2014/scripts/startup/rememberViewportSettings.mel line 43: Active stereo does not work with Aero enabled. Active stereo has been disabled. //
// untitled //
how do i fix these problems?? i have started an online animation school course, and am falling behind due to maya  constantly crashing
my specs
Acer Predator Helios 300 Gaming Laptop,
Intel Core i7 Processor,
32GB RAM,
1tbGB SSD,
GeForce RTX 2060
these are the messages i keep getting in  maya2016 - 2020
file -f -new;
// untitled //
commandPort -securityWarning -name commandportDefault;
onSetCurrentLayout "Maya Classic";
// Warning: file: C:\Users\shado\Documents\maya\2019\prefs\filePathEditorRegistryPrefs.mel line 4: filePathEditor: Attribute 'aiImage.filename' is invalid or is not designated 'usedAsFilename'. //
// Warning: file: C:\Users\shado\Documents\maya\2019\prefs\filePathEditorRegistryPrefs.mel line 5: filePathEditor: Attribute 'aiPhotometricLight.aiFilename' is invalid or is not designated 'usedAsFilename'. //
// Warning: file: C:\Users\shado\Documents\maya\2019\prefs\filePathEditorRegistryPrefs.mel line 6: filePathEditor: Attribute 'aiStandIn.dso' is invalid or is not designated 'usedAsFilename'. //
// Warning: file: C:\Users\shado\Documents\maya\2019\prefs\filePathEditorRegistryPrefs.mel line 7: filePathEditor: Attribute 'aiVolume.filename' is invalid or is not designated 'usedAsFilename'. //
// AbcExport v1.0 using Alembic 1.7.5 (built Feb 6 2018 18:28:08)
evalDeferred "shaderBallRendererMenuUpdate";
// Warning: line 1: filePathEditor: Attribute 'aiStandIn.dso' and label 'Standin' have been saved already. //
// Warning: line 1: filePathEditor: Attribute 'aiVolume.filename' and label 'VDB' have been saved already. //
// Warning: line 1: filePathEditor: Attribute 'aiImage.filename' and label 'Image' have been saved already. //
// Warning: line 1: filePathEditor: Attribute 'aiPhotometricLight.aiFilename' and label 'IES' have been saved already. //
import arnold
// Successfully imported python module 'arnold'
import mtoa
// Successfully imported python module 'mtoa'
import mtoa.cmds.registerArnoldRenderer;mtoa.cmds.registerArnoldRenderer.registerArnoldRenderer()
// Successfully registered renderer 'arnold'
updateRenderOverride;
// Warning: file: C:/Program Files/Autodesk/Maya2019/scripts/startup/autoLoadPlugin.mel line 35: Loading plug-in "mtoa" has resulted in changes to the scene that may need to be saved. //
// AbcImport v1.0 using Alembic 1.7.5 (built Feb 6 2018 18:28:08)
updateRendererUI;
updateRendererUI;
thank you all
Replies (0)
