Joints are not displayed in Isolate select mode with Maya2023
mihara_tomonari
mihara_tomonari
When I select joints or a group that contains joints and then Isolate select, the joints are not displayed. Is there any workaround?
Reproduces on Maya2023.2.
kelly_hynes
Can you provides some details of your workflow?  What settings are you using for Isolate select?   Testing builds here using the workflow in the attached gif does not repro the issue.
Kelly
Kelly Hynes
Manager, Software QA Engineering
Installation & Licensing forums | Contact product support | Autodesk AREA
mihara_tomonari
Thanks for the reply.
After deleting the prefs directory and examining the conditions in detail, it seems that the problem is reproduced when the rendering engine is set to DirectX11.
It was not reproduced with OpenGL Core Profile (Compatibily).
I am using Windows 10.
kelly_hynes
Thank you.  I can reproduce the issue.
Kelly Hynes
kelly_hynes
We tested this in our current branch builds and the issue appears to be resolved.
Thank you for reporting.
Kelly
Kelly Hynes
mihara_tomonari
Thank you.
We are waiting for the update to be released.
k_changgonzalez
Observer
Observer
Hello, I encountered this issue using Maya 2023 that I recently downloaded. When I isolate select joints, they disappear soon after entering isolate selection mode. They disappear when I move my around the viewport, or when I change my selection. Even if I do nothing, after a few moments of being in isolate selection mode the joints will disappear. I am using a Macbook Pro. Can someone help look into this issue?
