It is like a mess with layers, objects, etc...
1781navi
1781navi
Hello, I started designing an aircraft by layers. I have my first design finished but I can't control the parts in the layers. Most of the aircraft is combined and appears and disappears in several layers. (I am using "add selected objects” with the right button of the mouse). It is like a mess with layers, objects, etc... Parts in other layers disappear when they are not supposed to, when I switch off a different layer. There are parts and objects in several layers, but I just want them to be in one specific layer. The colors also do not match those of the layers. I made a little animation with the propellers, but I erased it, does this have anything to do?
How can I order my parts by layers to organize the design and to continue with the next level of the design? More detailed, more parts, more layers and so forth..thank you and kind regards, Navi
mspeer
Hi!
Please check the hierarchies and make sure that objects you want to have in a specific display layer are not part of an other hierarchy in an other layer, cause if you disable the visibility for an object this will impact all other objects lower in the hierarchy regardless of the display layer.
The display layer colors only effect the the wireframe color of objects.
