Issues with UV Mapping and Texturing in Maya After Exporting from 3ds Max
CHARLESFRNC1
CHARLESFRNC1
I'm currently working on a cinematic project involving a robot saving another robot from a car accident. The animation was created in 3ds Max 2023 and exported as an Alembic file to Maya 2025. The scene consists of animated baked geometry, with no reference files used in the workflow.
Resultantly, I am encountering issues with UV mapping after the file conversion. Most of the faces do not show up in the UV Editor when selected. I've tried remapping the UVs using the UV > Automatic tool in Maya, which hasn't been an adequate solution.
Here are some additional details:
  • Nature of the Project: Cinematic of a robot saving another robot from a car.
  • Software and Versions: Exported from 3ds Max 2023 as an Alembic and imported to Maya 2025 for texturing, lighting, VFX and rendering.
  • Textures and Materials: Starting from scratch for the car; have a set of textures for the robots. Need high-resolution textures formatted for Maya 2025 Arnold renderer with a realistic look.
  • Troubleshooting Steps Taken: Remapped UVs in Maya using the UV > Automatic tool.
  • Issues: UVs seem damaged after file conversion, and faces are not visible in the UV Editor.
I would appreciate any recommendations for tools, plugins, or workflows that could help resolve these issues.
Scene file:
https://drive.google.com/file/d/1hLRsbk0wvqKkwrFy6DpduNHTBBuJrGyb/view?usp=sharing
Thank you!
Best regards, Charlie Franco
我是水~
我理解上认为导出.abc应该是包含纹理的,我觉得可以检查一下几个方面
1.是不是有可能MAX中导出abc没有勾选UV选项,或者是否有特殊字符导致
2.是否可以尝试使用FBX并且将贴图打包在fbx中在maya里呈现
3.可以找第三方工具如blend来确定一下是max导出abc的问题,还是maya导入abc的问题
其实如果目的是渲染出视频的话,可以考虑在max里面渲染吧,max中也有Arnold的
