Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Issue while baking shoes in Maya 2018
3 REPLIES 3
338 Views, 3 Replies
Hi everyone,
I have low and high polys for shoes.
I made the baking of high poly onto low poly using Rendering > Lighting/shading > Transfer Maps.
Here is the normal map I've got.
As you can see, I am also having a projection of the polygons and that's the issue.
What can be wrong?
Thanks a lot.
3 REPLIES 3
hamsterHamster
Can you post a screenshot of the geometry, gray shaded? One of geos (rather lores) seems to have no smoothing.
,,,_°(O__O)°_,,,
Maya2019.1 @ Windows10 & GeForce GTX1080Ti
If the post was helpful, click the
 ACCEPT SOLUTION  button, so others might find it much more easily.
in reply to: hamsterHamster
Thanks for reply.
It has no smoothing.
Here is a screenshot of the low poly.
hamsterHamster
Exactly what I've mentioned - the lowres mesh has no edge smoothing.
Whether it is cause or not, select the geo (edges) and explore the Modeling>MeshDisplay menu; particularly, pay attention to Soften, Harden or Soften/Harden Edges options.
Once satisfied with how the shoes look in lowres, try the normal-map baking again.
,,,_°(O__O)°_,,,
