Issue - Opening a scene with Python, unsaved changes
Hello all,
So as of lately I'm unable to open scenes with Python (or Mel).
I keep getting a warning that my scene had unsaved changes and then it fails to open the scene.
I flush the scene first, and then open.
I also tried deleting my prefs and re-installing Maya. But none of it worked.
Anybody knows what's going on here?
I use something like this:
from maya import cmds
file_path = "/Users/David/Desktop/SH003SCENE_v001.mb"
cmds.file(new=True, force=True)
cmds.file(file_path, open=True)
hannesdelbeke
this will do the trick (untested)
cmds.file(file_path, open=True, force=True)
or in pymel (tested)
pm.openFile(scene_path, force=True)
when i create a new scene in maya, maya sees the scene as changed despite me not touching it.
you can see this if a * appears in the window title
the command you run creates a new scene so i would assume the same happening there
i did notice i had a security issue which might be the cause of this,
so make sure the maya security tools plugin is installed.
it can be found here https://apps.autodesk.com/MAYA/en/Detail/Index?id=8637238041954239715&appLang=en&os=Linux
