Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Is there any way to let navigation buttons momentarily change navigation modes?
4 REPLIES 4
Henrik_Cederblad
273 Views, 4 Replies
If memory serves me correctly, back in 2005 when I first used Maya, it would let you start any of the ROTATE, PAN, ZOOM navigation actions, during which you could momentarily press a different mouse button and the corresponding new navigation mode would seamlessly take over. In other words, you were not required to let go of the first navigation button before pressing a new one – and if you released the momentary button while still holding down the first button, Maya would uninterruptingly resume the original navigation mode.
… Is this all gone? I revisited Maya since I just began a 3D programme at university and now realize how much I miss this feature. Blender has it and I truly hope someone will jump in here and say it's achievable in Maya 2022 as well. I believe it might be called momentary keys, or something similar.
While we're at it – and in the same vein – I also wonder if there's a way to momentarily toggle snap with X and J after you've initiated a transform action. Please say there's a way to set this up.
4 REPLIES 4
mspeer
in reply to: Henrik_Cederblad
Hi!
This still works with Maya 2022.
(Tested with Maya 2022.2 on Windows.)
However this only works with the left and middle mouse key (not the right one).
Henrik_Cederblad
in reply to: mspeer
Yes, I forgot to mention that I was aware of that. Sorry! … It seemed to me there was a flaw in the current operation where only LMB and MMB works and (annoyingly) if you press RMB during the operation, it breaks the feature alltogether. So I was hoping this halfbaked function might suggest there's a possibility to somehow set this up to work properly … Is that a no go?
mspeer
Hi!
Sorry, I don't understand you, LMB and RMB work "properly"!
mspeer
in reply to: mspeer
Hi!
Correction, LMB and MMB (not RMB) work properly as in previous Maya versions.
