Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Is there a way to unfold the geometry to correspond with the UV Map?
2 REPLIES 2
369 Views, 2 Replies
So basically the geometry reflects the flattened UV coordinates:
2 REPLIES 2
sean.heasley
Hi @Anonymous
There isn't a way to do this natively in Maya.
You would need to create a plane for example and then model it to match the design you want and then UV map it.
I'm curious though as to why you would want to do this?
in reply to: sean.heasley
Was thinking up some experimental ideas, thanks for the input!
