Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Integrated Graphics
4 REPLIES 4
fiona_chandrasekaran
1823 Views, 4 Replies
Integrated Graphics
I need to buy a computer to run maya with for school (since the labs are closed due to COVID). Can anyone tell me if integrated graphics are a possibility? For example, would a 16gb laptop with integrated intel iris plus graphics work (I should be able to use a render farm for the class)
thank you!
4 REPLIES 4
Hello @fiona_chandrasekaran ,
Just checking to see if your problem has been solved. Did the response from @alec.andersenLP8AU help answer your question? If yes, please click on the "ACCEPT SOLUTION" button in his reply so this helps other users in the community find the solution too. Thanks!
Lynn Zhang
The Integrated Intel® Iris® Xe Graphics card is not listed among the certified or tested graphics card (
https://knowledge.autodesk.com/sites/default/files/HardwareCertification_Maya_Arnold_MotionBuilder_M...). However, @alec.andersenLP8AU replied "Should be ok! I'd check our system requirements and certified hardware guides to make sure though!".
Can someone confirm this card is not certified and has not yet been tested?
Thank you.
gavinsoares
in reply to: MiriamSterle
hello -
was there an answer - can Intel Iris Xe Graphics run maya 2018 even though it is not listed/tested?
thanks
gav
