Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Installing Maya 2022 Student Edition on Fedora 34 Workstation
3 REPLIES 3
ansonsavage
1001 Views, 3 Replies
I downloaded and unzipped the Maya Linux 64 Bit file and tried to run ./Setup file in the terminal. A GUI window with the title "Autodesk Install" appears temporarily, but then disappears and the following error messages are printed:
enter image description here
Do you have any tips for how to fix this? I am running Fedora 34 Workstation.
Thanks so much!
Labels (1)
3 REPLIES 3
Had anny succes installing maya on fedora ?
After things not propperly working on rhel i THought i might transition to fedora.
I wasn't able to install on Fedora, but I did get a somewhat working
install on Linux Mint! I had to use alien to convert rpm files to deb files
or something, haha! I can send you the tutorial I used if it would be
helpful. The main thing I couldn't get working was Arnold.
satmis99.99
in reply to: ansonsavage
DO not install maya from a setup in linux just install from here https://help.autodesk.com/view/MAYAUL/2022/ENU/?guid=GUID-D2B5433C-E0D2-421B-9BD8-24FED217FD7F    using terminal and it will work.
Also add  MAYA_NO_HOME = 1  in home/user_name/maya/2022/Maya.env
