Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Installing Arnold
2 REPLIES 2
ansonsavage
236 Views, 2 Replies
Installing Arnold
Hello!
I just installed Maya for Linux, and upon opening Maya, I receive the following message:
Warning: file: /usr/autodesk/maya/scripts/others/supportRenderers.mel line 67: The renderer "arnold" used by this scene, is not currently available. The "mayaSoftware" renderer will be used instead. To prevent this message from being displayed in the future, set the environment variable: MAYA_NO_WARNING_FOR_MISSING_DEFAULT_RENDERER=1 //
I've downloaded "Arnold-6.0.0.0_SDK_Linux" package, but I'm not sure how to connect it to Maya so that I can use Arnold. Could I get any pointers on this?
Thanks so much!
2 REPLIES 2
in reply to: ansonsavage
ansonsavage
I have, thank you! This may now be a problem on my end, but after following those instructions, Maya crashes with a Fatal error when I open the Plug-in Manager and select mtoa.so "Loaded." It's possible that it is because I'm running on Linux Mint, which is not an officially supported operating system. Any other thoughts for how I might fix this?
Thanks so much!
