Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Import Image not working
14 REPLIES 14
Message 1 of 15
austinlbeck
6748 Views, 14 Replies
I went to edit a photo in paint 3d and it wouldn't upload so i looked up on why and did what it said and now i can't even upload the original image instead it pops up fcheck window
Hi @austinlbeck your title 'Import Image' was edited for clarity by @sean.heasley
14 REPLIES 14
Message 2 of 15
sean.heasley
in reply to: austinlbeck
Hi @austinlbeck
Are you trying to import the image as an image plane or as an object?
Have you tried creating a new scene file and then try importing the image?
If this doesn't work, please attach the image here and I'll see if I can load it in Maya on my machine!
Let me know if anything changes!
Message 3 of 15
austinlbeck
in reply to: sean.heasley
Goku_Top,Side,Front.jpgYes I've done all of that and it used to work until i tried to edit the photo in paint 3d so then deleted all of the photos even that one and redownloaded it and still doen't work and as Image
Message 4 of 15
mspeer
Hi!
What means "does not work". Result, error messages,... ?
Message 5 of 15
austinlbeck
No image import will pop up fcheck
Message 6 of 15
sean.heasley
Hi @austinlbeck
I think the issue may be the image file type. When I downloaded it from here it wouldn't open in any image viewing program because the file type was broken.
To fix this, I renamed the image "Goku_Top.png" then I was able to load it into Maya just fine.
Please let me know if this helps or if you need any more assistance!
If one or more of these posts helped answer your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Kudos are greatly appreciated. Everyone likes a thumbs up!
Message 7 of 15
austinlbeck
Yeah thanks but no it didn't work
Message 8 of 15
sean.heasley
Hi @austinlbeck
When you get a chance, can you please post a video of this issue happening so I can get a better idea of how to assist you?
Message 9 of 15
austinlbeck
Yeah i should be able to do it around 2:00- 2:30pm
Message 10 of 15
austinlbeck
Message 11 of 15
sean.heasley
Hi @austinlbeck
Thanks for providing the video!
It was a little bit hard to tell but it looks like you had the picture labeled as jpg right? If so then it should be working as normal.
Out of curiosity, could you try going to a specific view like the side or top view then go to View->Image Plane->Import and see if that works?
Message 12 of 15
mspeer
Hi!
Don't do it this way, this will not work as you want.
Images can't exist "alone" in Maya, you can only create a link to an image from inside a node.
First decide what you want to do and where you need the image, then create what you need to add the image to and then add the image.
For example:
1. Create an object
2. Add a material
3. Add a texture (create the file node and specify the image location there)
or Drag and Drop a file from OS into Hypershade (this creates a file node with the correct link).
Message 13 of 15
austinlbeck
yes that worked thanks
Message 14 of 15
steinmannk1
Yes I am trying to use theses two pictures i took for maya but they wont go through.clouds.jpgcity.jpg
Message 15 of 15
damaggio
in reply to: steinmannk1
They won't go where?  show the connections please.
