Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
I want to create a hotkey to toggle between Weighted Tangent and Non-Weighted Tangent.
2 REPLIES 2
amaterasu-qbb
218 Views, 2 Replies
Hi! everyone
I am currently writing code to toggle between Weighted Tangent and Non-Weighted Tangent for the Graph Editor keys. To assign it to a hotkey. I found that this command can be used to toggle between Weighted Tangent and Non-Weighted Tangent.
import maya.cmds as cmds
cmds.keyTangent(wt = True)
cmds.keyTangent(wt = False)
I want to switch using the if, but I can't do it. Why is it not working? What part of the program can I fix to have it work?
if cmds.keyTangent(wt = True):
else: cmds.keyTangent(wt = True)
https://help.autodesk.com/view/MAYAUL/2024/ENU/?guid=__CommandsPython_index_html
Note: switching a curve from weightedTangents true to false and back to true again will not preserve fixed tangents properly.
I agree with this. Any advice you can give me would be appreciated.
Labels (2)
2 REPLIES 2
Sorry for the late reply, @9boz on Twitter gave me the code: https://forums.autodesk.com/t5/maya-programming/python-using-if-and-else-to-toggle-between-a-weighte...
The following code is based on the code he gave me. I hope it is useful.
# Toggle Weighted Tangent, Non-Weighted Tangents.
cmds.keyTangent(e = True, wt = not(cmds.keyTangent(q = True, wt = True)[0]))
# Toggle Weighted Tangent, Non-Weighted Tangents by selected Anim Curves.
selectedCurves = cmds.keyframe(q=True,name = True,selected = True) or []
for selectedCurve in selectedCurves:
    cmds.keyTangent(selectedCurve,e = True,wt = not(cmds.keyTangent(selectedCurve,q = True, wt = True)[0]))
Also, @Kahylan gave me a modified version of the code I posted in my Maya forum question. I think this will be useful as well.
# set to Non-Weighted Tangents, False.
if cmds.keyTangent(q = True, wt = True) == [True]:
    cmds.keyTangent(e = True, wt = False)
# toggle Weighted Tangents.
else:
    cmds.keyTangent(e = True, wt = True)
I Accept Solution to this answer but this is not by me, it was helped by @9boz and @Kahylan. But I accept the solution because it helps the community.
I would like to take this opportunity to thank @9boz and @Kahylan
Thanks to @9boz and @Kahylan's help, I was able to create a code to toggle between Lock Tangent Length and Free Tangent Length, so I will post it here as well.
# Toggle Lock Tangent Length or Free Tangent Length.
cmds.keyTangent(e = True, wl = not(cmds.keyTangent(q = True, wl = True)[0]))
