Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
i need a little help
4 REPLIES 4
freemdiepie
209 Views, 4 Replies
can someone help me how to fix this.
i use a shader then after i render it it looks like distorted.
4 REPLIES 4
mspeer
in reply to: freemdiepie
Hi!
1. Check and maybe correct the displacement values in the material.
2. Increase the value for "Bounds Padding" in the Arnold tab of your shape node.
freemdiepie
in reply to: mspeer
it didn't work.
it just make it worst
Not so sure about Arnold settings, but uvs look chaotic in the render, even in the viewport those are fine.
Can you check the state of UVs, particularly, how many uvSets there are? You might need to delete the messy one, unless you find where to disable its influence on the rendered image.
,,,_°(O__O)°_,,,
Maya2019.1 @ Windows10 & GeForce GTX1080Ti
If the post was helpful, click the
 ACCEPT SOLUTION  button, so others might find it much more easily.
mspeer
Hi!
For further help, please provide a scene-file and the texture used for displacement.
