Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
I import OBJ from Cinema4D but it show only a blank in Maya
2 REPLIES 2
858 Views, 2 Replies
Hello!
I draw spline vertex and extrude them to make a model and save as obj/fbx. Everything is fine because I can see it and can view it in window 3D viewer, but when I import that obj/FBX file in to Maya then Maya show nothing.
On the outliner display I can see that it show that OBJ "name:Mesh" but when I click on it there is nothing happen.
Please help me, thank you.
2 REPLIES 2
hamsterHamster
I never was able to import/export anything Nurbs related as OBJ into Maya since it's v1.0. No information in the Documentation.
Try FBX format - I just tested: exported Nurb curve and its revolved Surface. Imported the same, just without construction history.
,,,_°(O__O)°_,,,
Maya2019.1 @ Windows10 & GeForce GTX1080Ti
If the post was helpful, click the
 ACCEPT SOLUTION  button, so others might find it much more easily.
I tried again to export file from C4D as FBX and deleted every history, it worked now. thank you!
