Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Hypershader not showing shader ball in material viewer
4 REPLIES 4
majko.valovic
6921 Views, 4 Replies
I am using maya 2017 and when i tried to do some texturing using hypershader, it didn't go so well, it just doesn't show any mesh in material viewer, its just blank space, nothing is helping, I tried to update my graphics driver (Intel HD graphics 3000), I tried changing working units, I tried different resolution for swatches, changing rendering engine and now I am quite desperate.
4 REPLIES 4
mspeer
in reply to: majko.valovic
Hi!
For Maya you need an appropriate Graphic Card to work properly. But you may try a reset of your preferences.
Rename the folder prefs in folder 2017 to something like prefs_backup, or to reset everything, the folder 2017 to 2017_backup. Maya creates new folders. Detailed at:
https://knowledge.autodesk.com/support/maya/troubleshooting/caas/sfdcarticles/sfdcarticles/Reset-May...
majko.valovic
in reply to: mspeer
Thank you, i tried reseting it but nothing changed.
I guess I need another graphics card.
Anyway thank you very much! 🙂
I had this issue as well. Deleted prefs folder as said above and didn't work. However what did work is clicking the little camera icon with a circular arrow swirl that says "Reset Camera Transform." This brought the shader ball back into view.
This worked for me , thank you .
