Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
How to use multiple proxies in MASH
5 REPLIES 5
yoony1010
235 Views, 5 Replies
I'm working on forest environment.
I made 3 different tree modeling files into 3 different proxy files using vrmesh with dummy for preview and trying to make one MASH network(checked 'instance') with selecting all of them.
But when I try to place those using Placer Node, only first proxy shows in viewport. Second one shows only vertexs, and last one doesn't even show up at all. but I can see all of them on render view.
Is there anyway can make all of 3 proxies shows in viewport not only in render view? I searched about this few days, but still can't figure it..
It seem I can only use only one proxy for one MASH network.. is it correct? Is there anyway can use multiple proxies for one MASH network? 😞
I'm using MAYA 2020.4/Vray v5.20.01. Thanks in advance !:)
5 REPLIES 5
I assume thats a limitation of the viewport.
And cause that workflow is outdated i wont hope for a fix.
https://linktr.ee/cg_oglu
Oh! I see. Thanks for your respond!:)
And may I ask you some advice?? I'm still learning Maya so I didn't know it was old way..:(
How about placing every tree as mesh and then make all of them into proxy?
I'll use this scene in a short animation so hope to make it not too heavy....
What about using Vray scatter?
I would go that way if i need a light scene.
https://www.youtube.com/watch?v=PrsrmKYIwYU
If you are a beginner using Bifrost would be a big step but you could try it too.
https://youtu.be/yevvBz1eVO8?si=oElRqgQcteLx3_q0
Wow I didn't know that there's other way than MASH!! Thank you soooo much I'll definitely try it!
Have a great day!:)
