Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
How to transfer or copy XGen hair ?
5 REPLIES 5
yioafget435fsgzvnyd
6127 Views, 5 Replies
Hello, i have two questions that need to help.
1.How to transfer XGen hair? For example:when i have made the XGen hair on a model ,if i  want to change another model ,how can i directly transfer the done XGen hair to another model ,then i'll don't need combing again.
2.How to copy the XGen hair?
       Thank you!
5 REPLIES 5
Double Post because Chrome is wierd
Michael Todd
XGen Product Owner and Designer
In another post I gave this answer about transferring XGen:
XGen Transfer
For the new system in 2017, Interactive Grooming, it's much easier.
If you want to transfer to a new mesh, with different topology but similar shape:
You just select the description and the target mesh:
then hit Transfer:
and the description will be transferred to the new mesh.
The you can add modifiers and make changes as needed.
Cheers
Michael Todd
Parmenides
in reply to: Michael_Todd
Very useful info and explanation, thanks. For my model I tried the Transfer method but Maya always hung while writing a temp file.  I was however able to export the definitions and re-import them successfully onto other geometry.  (2018.4).
s11390
in reply to: Parmenides
Hi
Recently I tried to transfer a tiger fur into a head only model (just cut the body part) via interactive groom tool. The result is very weird as the image I post. Is there any solution ?  Thanksafter_transfered.jpg
dorianaUXM8D
How do you do it with the non-interactive xgen?
