Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
How To: Supress FBX dialog on Export
1 REPLY 1
jake_black
175 Views, 1 Reply
I'm exporting meshes very often to .FBX and the settings that I use are correct, I don't want to specify them each time. Is there a way to select an object and export without the settings window, just save as that type and move on with it?
1 REPLY 1
hamsterHamster
in reply to: jake_black
Which kind of dialog are you referring to? Once you have everything FBX-supported, there should be no FBX-warning/info window.
Also, you can copy the export command from the ScriptEditor and turn it into MEL/Python button, which will look smth like this:
file -force -options "" -typ "FBX export" -pr -es "Z:/MyProjects/CurrentProject/scenes/test.fbx";
,,,_°(O__O)°_,,,
Maya2019.1 @ Windows10 & GeForce GTX1080Ti
If the post was helpful, click the
 ACCEPT SOLUTION  button, so others might find it much more easily.
