How to straighten edge loops in maya?
ruediger.hahn
ruediger.hahn
how can I straighten the selected edge loop?
It seems to be a one key issue. But I do not understand the tutorial guy.
Lost in translation! 😄
thanks in advance.
Replies (21)
pshwayka
With the loop selected, use the scale (r) tool. (Scale in one axis only...probably x in your case.)
ruediger.hahn
this one works. I often forget the force of the scale.
But the tutor says about hold ... key down and it snaps to straight.
Terrible English and no subtitle. I try to find out which one.
_sebastian_f
that could be x (grid snapping) or v (point snapping). depending on where you want the loop to be i prefer scaling it as @pshwayka said so you get an average of the current position.
ruediger.hahn
X will snap grip and V snap to point
I think he says J, but it does not horizontal or vertical align with me.
Something I do wrong.
pshwayka
I usually use the J key to do rotation snapping. by default, if you rotate with the J key held down, the rotation will be in 15 degree increments.
ruediger.hahn
But it would not straighten it. If it is off and you turn edge loop you itwould not mean it stops at 90º.
_sebastian_f
exactly, it just increments from the current position/rotation. if it´s an arbitrary value you will not get it straight. that´s why we proposed other methods. if you are not happy with it link the the tutorial. maybe someone can tell you what the guy is using.
pshwayka
Note that you can specify the snap increment in the rotate tool settings under snap step, and make it relative or absolute...but I still prefer the scale method for what you're trying to do.
ruediger.hahn
The tutorial is the one from pluralsight 'advanced charcacter modeling in maya'. part 3.
the scale method works fine when the edge is rotate even. but when you look on the picture the selected edge loop is non uniformaly deformed.
*edit: sorry maybe not so visible. but tutor uses one key and it snaps straight. but I do not get which key.
And manually adjusted is not 100% straight.
pshwayka
Since you're paying for that tutorial, you should be entitled to clarification. Have you tried asking them for help?
ruediger.hahn
It hought this might be the faster way. I asked once a question and it took them for ever. No direct contatct to the tutor. But I did not expect to ask something so strange. 🙂 I am sorry for causing so much back and for.
pshwayka
Okay...I just signed up for a free trial, and that particular video was available. What he's doing is holding down the J key while he uses the scale tool with the Y axis handle (green.) That does indeed work.
ruediger.hahn
Thanks for the extra work!!
I did not try it on scale. THANKS!!
happy!
pshwayka
Glad that mystery is solved!
Smiley Happy
ruediger.hahn
So You also did learn something. 😉
pshwayka
Seems like extra effort to me...I can get the same result just by using the scale tool...with just one hand.
Smiley Wink
pshwayka
Also, @_sebastian_f just reminded me of something...beginning with Maya 2015, the scale tool has a "prevent negative scale" option which is enabled by default, and which allows you to just use the scale handle instead of the snap option.
undefined
ruediger.hahn
You are right. I thought it prevented the movement in horizonatl edges but it does not. So no idea why he does it. I got confused, did not get and so I had to ask. But studying by myself means... ask in Forums and watch more tutorials.
ruediger.hahn
must be with 2016.
Using a 2015 student version, where it is not showing up.
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
