Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
How to select all objects that dont have material assigned?
3 REPLIES 3
4494 Views, 3 Replies
Hello friends,
I have a lot of objects that don't have material assigned, and all of these object are covered by a single texture map. How do I select all the objects that don't have material assigned?
Help please!
3 REPLIES 3
sean.heasley
Hi @Anonymous
Simple way to do this would be to select all of the shaders in your hypershade except for the default lambert shader, right click, hit select objects with shader, go Edit -> invert selection.
This should then select all of the objects with no materials assigned to them.
Please let me know if this helps or if you need any more assistance!
If one or more of these posts helped answer your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Kudos are greatly appreciated. Everyone likes a thumbs up!
J450NP13
in reply to: sean.heasley
This isn't a solution.  There isn't even a "invert selection" int he hypershaders Edit dropdown.
Am I missing something?
mspeer
in reply to: J450NP13
This menu has been moved.
Use in main menu:
Select -> Invert
