Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
How to reset renderer settings? (Arnold)
8 REPLIES 8
Message 1 of 9
zenlink0
12976 Views, 8 Replies
I've been messing around with my Arnold render settings so much that I couldn't replicate my initial render. I tried deleting my prefs file but that doesn't work either.
8 REPLIES 8
Message 2 of 9
sean.heasley
in reply to: zenlink0
Hi @zenlink0
I'm not an arnold expert but I have two ideas.
One is you could unload the Arnold plug-in and reload it.
Two is to make a new scene and import everything from your current scene to it then try to render.
Let me know if anything changes!
Please hit the Accept as Solution button if my post fully solves your issue, or reply with additional details if the problem persists.
Kudos are greatly appreciated. Everyone likes a thumbs up!
Message 3 of 9
Stephen.Blair
If you had an EXR rendered with the initial settings, you could check the metadata in the EXR header.
// Stephen Blair
// Arnold Renderer Support
Message 4 of 9
djonesuk
Have you tried opening Render Settings and clicking Presets, Load Preset, Default Settings?
Message 5 of 9
sean.heasley
in reply to: djonesuk
Hi @zenlink0 just checking in, are you still having this issue?
Sorry about that @djonesuk 😛
Message 6 of 9
djonesuk
in reply to: sean.heasley
Hi Sean, I wasn't the one with the issue.
Message 7 of 9
zenlink0
Sorry everyone, I changed the settings till I got another result that I liked and sticked with it. I don't want to mess with the setting anymore. Maybe someone else can post their result of resetting render that the others suggested?
Message 8 of 9
here and I would suggest each time you get a setting you like save it as a jason file so you can come back to it later
in the same menu just save the preset
also please mark this post as solved if you are ok with this solution, give it to the person who suggested it first.
Message 9 of 9
Hello all. I have an issue about the arnold render settings window. The tab Common is not shown correctly.. it shows only a disturbed 5% in the upper left corner in the render settings window.. I tried to reset the view by selecting the default preset option but it didnt work..
thanx for advices
