Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
How to make tick span 5 in maya2019?
4 REPLIES 4
amaterasu-qbb
209 Views, 4 Replies
I can use 10, but not 5. why and how to make it 5?
10 Tick span.10 Tick span.5 Tick span.5 Tick span.
This is my Spec.
Maya version 2019
Intel i7-7700 CPU @ 3.60GHz 3.60 GHz
Installed RAM 16.0 GB
System type 64-bit operating system, x64-based processor(Windows10 pro Version21H1)
Wacom Intuos Pro S
Dell P2415Q 4k (Windows setting Scale and Layout 175%)
Tags (3)
Labels (2)
4 REPLIES 4
Parmenides
in reply to: amaterasu-qbb
  Odd, doesn't work for me either.  3 and 7 work though...
Using Mac OS 12.4 Maya 2023.1
Hi! everyone.
I figured out how to set the tick span to 5 with Maya2024 Creative. It may be possible to do the same in Maya 2024.
If you set Tick Span to "9999999999" in preference, it will show 5 at a time.
tick span is 5.tick span is 5.
But, if I save the preference, quit Maya, and restart Maya, it changes to 0. If I save the preference, quit Maya, shut down the PC, restart the PC, and restart Maya, it also changes to 0.
I have reported this to Autodesk just in case.
Thanks.
brentmc
I can confirm that this is a bug and tick span of 5 is not currently supported so we've opened an issue to address this in a future release. There is also no workaround for this except to use a different tick span. (like 10)
MAYA-76001: Time Slider Tick Span of 5 doesn't work
Thanks.
Brent McPherson
Principle Engineer
amaterasu-qbb
in reply to: brentmc
Hi! @brentmc ,
Thank you for your work on this issue.
Thanks.
