how to make a node unselectable in the UI
BurkhardRammner
BurkhardRammner
every now and then, I select an 'objectSet' node, which has too heavy meshes/shadingEngine data in it.
The consequence is that Maya never returns from the resulting (unnecessary) calculations..
So...is there any functionality for making a node unselectable in the outliner/UI?
thanks!
hamsterHamster
I don't know about unselectable, we can hide the objectSets from the editors, Outliner particularly.
In the Outliner>Show>AuxiliaryNodes... click the bottom list item and cycle through the names by continuously clicking o-key, until you find objectSet > addToHideList(Above).
,,,_°(O__O)°_,,,
Maya2019.1 @ Windows10 & GeForce GTX1080Ti
If the post was helpful, click the
 ACCEPT SOLUTION  button, so others might find it much more easily.
BurkhardRammner
@hamsterHamster
Thanks for your answer. However, I made my own outliner variants, the relevant one is only for set nodes ; ]
And I would need the option to make specific set nodes unselectable...
