Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
How to extrude correctly a straight curve
2 REPLIES 2
KVSpencer
957 Views, 2 Replies
Hello I created this curve
ad77427bdf
When i exturde it, that happens
4e99dbfbff
How can i do rounded corners for that cable but keep it straight?
2 REPLIES 2
KVSpencer
in reply to: KVSpencer
up
mspeer
Hi!
To get rounded corners with extrude you need a rounded curve for the path. A higher curve degree (2 or 3 should be enough) and the usage of more curve points (control vertices) give you a better control over a smooth roundness.
If you ask about the artifacts you get with your extrude, please post your scene-file.
Technology Administrators
