Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
How to export/import RenderSetup with .mb/.ma?
1 REPLY 1
g2m.agent
183 Views, 1 Reply
Labels (3)
1 REPLY 1
daunish
in reply to: g2m.agent
I assume you mean you want to export your render setup by itself in an ma? So you would want to be able to import it into a new scene and have it still function as a render setup?
If so I'm afraid it's not going to work. When render setup is imported or referenced into a new scene it basically removes itself. The correct workflow would be to export your setup as a json file (its native format). This can be very easily done inside of the render setup window. All you would need to do is select the layers you want to export and hit export. Then in your new scene import the layers back in from the render setup window.
Hope this helps!
