Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
How to emit fluid from particle spheres?
0 REPLIES 0
Message 1 of 1
eldersamkennedy
106 Views, 0 Replies
I have created a particle emitter which generates spheres that gradually increase in radius as they age:
I have linked this with a fluid using Fluids -> Add/Edit Contents -> Emit from Object, however when the fluid is created it does not match the size of the spheres:
I guess I'm missing something with either the particle or fluid emitter attributes, I have experimented with different settings (changing volume shape to sphere instead of cube, changing from a surface to a volume emitter etc.)
The goal is to have more fluid generated inside the larger spheres and less inside the smaller spheres, any guidance on how to achieve this would be greatly appreciated 🙂
0 REPLIES 0
