Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
How to cut a curvy part out of a mesh
3 REPLIES 3
mikhailkonstantin3d
467 Views, 3 Replies
Greetings,
 i have modeled this 3D Logo and i would like to cut a curvy shape out of it, can you please help with that ?
if you see in the Side-X view the selected part should be cut away (Deleted) to look like in the Perspective view, it's not visible
Labels (1)
3 REPLIES 3
Do it with a boolean.
Thank you for your reply sir, but, i know that Boolean or Multi-cut tool can help, but my question is, can it be done using a Curve line for example ? so i can draw it exactly as the shape is curved ??
Hi @mikhailkonstantin3d,
While you certainly could model the object to have an end with a curve that matches your shape, it might be easier to simply lift the related vertices or faces to hide them. Oftentimes, the best solution (and the least expensive in terms of polys) is the simplest!
