Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
How to create file path attribute in maya using Python API
2 REPLIES 2
subing85
185 Views, 2 Replies
I want to create a new attribute to set the file path, for example in the file node attribute called "fileTextureName".
I tried to swap from file node fileTextureName to one transform node,  I am looking for better way to create file path attribute.
This is the experiment source code
from maya import OpenMaya
node = "locator1"
attribute = "file1.fileTextureName"
# get the mobject from locator1
mselection = OpenMaya.MSelectionList()
mselection.add(node)
mobject = OpenMaya.MObject()
mselection.getDependNode(0, mobject)
# get the plug from file1.fileTextureName
mplug = OpenMaya.MPlug()
mselection.add(attribute)
mselection.getPlug(0, mplug)
# add the attribute to locator1
depNode = OpenMaya.MFnDependencyNode(mobject)
depNode.addAttribute(mplug.attribute())
Anyone helps, that should be appreciable.
Tags (1)
2 REPLIES 2
subing85
in reply to: subing85
I got the solution for this, just ignore my question
zewt
It's always nice to mention what the solution was, since other people also searching for it will find this question--and be frustrated when it just says "nevermind got it" without giving any more info 🙂
(The answer was probably using MFnAttribute::setUsedAsFilename to mark the attribute as a filename)
