Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
How to change Maya help default browser?
17 REPLIES 17
Message 1 of 18
veeramani4
4279 Views, 17 Replies
I have edge browser only. But Maya help asking firebox. now how to change  for my default edge  browser for maya
Hi @veeramani4 your title 'browser' was edited for clarity by @sean.heasley
17 REPLIES 17
Message 2 of 18
sean.heasley
in reply to: veeramani4
Hi @veeramani4
This was solved in another thread so it should be easy for you! I'll post the solutions from that thread below as well!
You can edit your Windows registry by running regedit.
Set HKEY_CURRENT_USER\Software\Classes\.htm to ChromeHTML
(Note: Since you use Firefox sadly FirefoxHTML wont work, one user used FirefoxHTML-308046B0AF4A39CB)
You can also manually do this inside of Maya in the script editor by running this code:
import _winreg
htm = _winreg.OpenKey(_winreg.HKEY_CURRENT_USER,"SOFTWARE\\Classes\\.htm", 0, _winreg.KEY_ALL_ACCESS)
_winreg.SetValueEx(htm, '', 0, 1, "ChromeHTML")
_winreg.CloseKey(htm)
Please let me know if this solves your issue or if you need any more assistance!
If one or more of these posts helped answer your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Kudos are greatly appreciated. Everyone likes a thumbs up!
Message 3 of 18
veeramani4
in reply to: sean.heasley
first               issue 'firebox' make sure you typed name correctly
now another issue 'chrome' make sure you typed name correctly
Message 4 of 18
sean.heasley
Hi @veeramani4
I'm a little bit confused. Did you get an error saying the names weren't typed correctly?
Did you type them out as ChromeHTML or FirefoxHTML?
Let me know if anything changes!
Message 5 of 18
veeramani4
first firebox it is not my browser. after you instructed I change my availability chrome changed , after that message also changed. I had  done python script editor
Message 6 of 18
sean.heasley
Ah my mistake! I thought it was firefox you were trying to switch to not Edge.
Do you have any other browser installed? Generally Maya will open either your default web browser or Internet Explorer.
Is edge set to be your default browser?
Message 7 of 18
veeramani4
Yess
Message 8 of 18
sean.heasley
Hi @veeramani4
I need a bit more information to make sure there isn't anything weird happening with your browsers.
  • Yes to Edge being your default browser?
  • Do you have any other browsers installed or only edge?
  • What browser is opening when you launch the help tool?
Let me know when you get a chance!
Message 9 of 18
veeramani4
OK now changed edge default browser
Message 10 of 18
sean.heasley
So now that edge is your default browser, what happens when you press the Help button in Maya?
Message 11 of 18
veeramani4
Message 12 of 18
veeramani4
I am using Microsoft edge browser. in maya I go to help one error message have received how to solve this one
Message 13 of 18
sean.heasley
Hi @veeramani4
Do you have Chrome installed?
In the code I provided,
import _winreg
Did you copy it exactly like this so it says ChromeHTML?
Also what version of Maya are you running? This code works in Maya 2018 but I don't believe it works in earlier versions of Maya.
Please let me know when you get a chance!
Message 14 of 18
veeramani4
confusing me I want to configuration Microsoft edge for help browsing in maya. how to configure  that
Message 15 of 18
sean.heasley
Hi @veeramani4
I'm not sure if it is possible for Edge to be the default browser for the Maya Help menu.
When you get a chance, can you please provide me with some more information
  • What version of Maya are you using?
  • Do you have any browsers installed other than Edge?
Please let me know if anything changes!
Message 16 of 18
infoWRWS8
worked!  (I pasted the script into the script window)
Thanks!
Message 17 of 18
Not working here Maya 2018.4!
// Error: htm = _winreg.OpenKey(_winreg.HKEY_CURRENT_USER,"SOFTWARE\\Classes\\.htm", 0, _winreg.KEY_ALL_ACCESS)
// Error: Line 2.5: Syntax error //
Syntax error.
Message 18 of 18
hi
in reply to: laomusic_arts
Changing the registry did not work for me.
Windows has done some underhanded things with its "default browser" settings in Windows 10.
Not only do you need to change the default browser but you also have to change the file type association with .htm and .html
Do this by opening settings and searching "Choose default apps by file type" then scroll down to .htm and .html and change it to whatever you'd like.
