AREA content is being relocated to the Autodesk Community M&E Hub and Gallery. Notifications may be intermittently unavailable 10–12 November. Learn more HERE.
How to add MASH network to a Render Layer Collection
A MASH network with geo type set to instances is not selectable in the outliner.
Because it is not selectable I cannot add it to a collection in a render layer.
The workaround is to export the MASH network as a proxy (using Redshift) then bring that back into my scene to add it a render layer.
Is there a better way to do this?
Thanks!
robin.berressemN45JX
Observer
Observer
Hey, had the same problem.....
For me it worked to bake the MASH Instancer to Objects. Under: MASH>Utilities>Bake Instancer to Object.
Hope this will help some people. (:
wzwow
this works but is it so retarded....
Jean-MarcBERNARDELLO8456
Observer
Observer
Try to add the instanced object and the mash_instancer in your collection.
Kind regards.
wzwow
I had tried that, it wont work....
Observer
Observer
As you can see on the pictures below it works for me on Maya 2023.
