Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
How do I delete the cache of the reduce function?
1 REPLY 1
SoulCat
175 Views, 1 Reply
my autodesk maya is not working properly anymore
what I did
1) select a complex 3D object/shape
2) select -> Mesh -> Reduce
3) I then open task manager and killed the maya process while maya was halfway reducing the 3D object
now every time when I start maya and open the file of the same 3D object
my maya will auto start the mesh -> reduce function  with out me starting it.
I believe I need to delete the cache of this maya reduce function
Can you please give me the directory structure to delete in maya to delete the cache of this reduce function?
Thank You Much Much
1 REPLY 1
mspeer
in reply to: SoulCat
Hi!
a) Select the object in Maya and use
Edit -> Delete by Type -> History, or
b) Edit -> Delete All by Type -> History
(for all objects in the scene)
