Announcements
AREA content is being relocated to the Autodesk Community M&E Hub and Gallery. Notifications may be intermittently unavailable 10–12 November. Learn more HERE.
how can I remove transparency?
Message 1 of 8
I try to make texture painting without transparency. How can I fix it?Screen Shot 2018-03-31 at 6.06.38 PM.png
Replies (7)
Message 2 of 8
mspeer
Hi!
Set Transparency for the material to "0".
Message 3 of 8
By accident, I linked the transparency with the .psd file. I cannot move the slide bar at attribute editor.Screen Shot 2018-03-31 at 11.10.26 PM.png
Message 4 of 8
mspeer
Hi!
Disconnect it (right-mouse-click).
Please read the Maya Online Help / Documentation for more details.
Message 5 of 8
It worked and I found how to fix it. Thanks!
Message 6 of 8
how do you fixed it? i still cant find the solution
Message 7 of 8
rogodoy
Go to renderer> Viewport 2.0 >Change settings  find Transparency Algorithm> assign Alpha Cut.  It will fix this issue.
Message 8 of 8
toyyoda95
This solved it when absolutely nothing else worked thank you
