Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Hotkey Editor
3 REPLIES 3
361 Views, 3 Replies
Hotkey Editor
Hi, how can assign 2 same hotkeys for different Menu, For example:
CTRL + E in Modeling menu is extrude
CTRL + E in Animation menu is Delete key in frame
Thank you, in advance!
Tags (2)
3 REPLIES 3
sean.heasley
Hi @Anonymous
Yes you can!
When you open the Hotkey Editor you just need to change the Edit Hotkeys tab and pick the specific window/tab you want to edit in the dropdown.
From there simply assign the keys like normal.
sean.heasley
in reply to: sean.heasley
Hi @Anonymous
I'm just checking in again to see if you need more help with this. Did the suggestion I provided yesterday work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Thank you, it helped me a lot!
