Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Hide UV's and mesh in viewport while editing UV
5 REPLIES 5
andy.engelkemier
3319 Views, 5 Replies
I haven't used Maya in maybe 12 years, soooo I'm a bit rusty.
I can't seem to even figure out how to search for this. While editing UV's I'd like to see the model textured, with no mesh lines, UV's or verts of any sort. It's So much easier to figure out what things look like.
Can someone help me in the direction of toggling that? I've searched quite a bit, but not coming up with anything. I'm using 2018.
5 REPLIES 5
mspeer
in reply to: andy.engelkemier
Hi!
Viewport menu: Show -> Selection Highlighting
alison.zulmea
in reply to: mspeer
hello,
I have the same problem but I already have selection highlighting on ...
i don't know what to do ..
Tags (1)
mspeer
in reply to: alison.zulmea
Hi!
You need to disable Selection Highlighting.
If you still see some components, you need to disable them in Viewport menu (Shading > ...) or with Attribute Editor in the Shape itself.
I also wonder how to work with UVs in the UV Editor while at the same time actually seeing how the texture looks in the viewport. Show > Selection Highlighting does not affect the issue I have, which might be the same as @andy.engelkemier had?
Question: How do you disable showing the UV shell in the Viewport while having the shell selected in the UV Editor?
l.braun
in reply to: Henrik_Cederblad
hi
It might be a bit late... I think you only need to close the UV editor window :)))
