Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Having problem to delete seams
8 REPLIES 8
Message 1 of 9
mulfycrowh
425 Views, 8 Replies
Hi everyone,
I am working on a low poly character and I would like to change some seams without resetting everything.
I would like to delete the seams shown by the red arrows.
I tried Ctrl + Click on each seam to sew but without success.
Any idea?
Thank you so much.
8 REPLIES 8
Message 2 of 9
hamsterHamster
in reply to: mulfycrowh
With those edges selected, try sewing from the Modeling>UV>uvEditor window.
,,,_°(O__O)°_,,,
Maya2019.1 @ Windows10 & GeForce GTX1080Ti
If the post was helpful, click the
 ACCEPT SOLUTION  button, so others might find it much more easily.
Message 3 of 9
mulfycrowh
in reply to: hamsterHamster
Thanks for reply.
I tried but it doesn't run
Message 4 of 9
hamsterHamster
Doesn't-s and Can't-s alone are not the way to the solution. If you are interested in finding one, learning something, post something to work with, like your model - zipped MA file.
,,,_°(O__O)°_,,,
Message 5 of 9
mulfycrowh
Thanks for reply.
Here attached the Maya file.
Message 6 of 9
hamsterHamster
The specifics of the uv layout is that is split in UDIMs.
And then, the head uvs, that border with seams that you want to get rid of, seem all to be snapped to a (0.000, 0.000) point. Here only reasonable option would be to auto-project uvs for that head part, then re-define (Cut) the new seam at the neck, and merge leftover uvs to the torso. You might need to use some Unfold/Optimeze commands/tools, to untangle some overlapping/heavily deformed parts.
,,,_°(O__O)°_,,,
Message 7 of 9
mulfycrowh
Thanks.
It explains the trouble.
The easiest way is probably to reset everything.
Message 8 of 9
hamsterHamster
Probably, if you'd enjoy mapping entire body instead of just head part.
,,,_°(O__O)°_,,,
Message 9 of 9
mulfycrowh
That's right.
I have to map the entire body
