Harden Edge Light Leak
Hello All,
I am making a low poly game in Unity. I am creating simple objects in Maya and using the harden edge tool to get that good looking effect I am going for.
However, whenever I harden the edge of any model light starts to leak. The picture above shows the same object two different times. The only difference is the object on the left has harden edge applied to it, which you can see the light leak from the shadow. The one on the right does not have harden edge or the light leak.
The only tool I am using is harden edge.
Any advice or help would appreciated!
I don't know the solution but I'm guessing it has to be with Unity rather than Maya, I think, I'd suggest you to post it on an Unity forum too
