Full screen mode?
This widget could not be displayed.
Full screen mode?
First of all I love the new UI in Maya 2011.
I now want to make the most of my desktop real estate. Is there a way to perhaps force full screen mode like in Toxic? ie. to remove the title bar and border?
If anyone knows of a third-party app/plugin/utility that would have the same result it would be much appreciated if you point me in the right direction.
Replies (9)
Great Idea!
Well, I don't know about Maya 2011, but when I model on Maya 9 using a 27" screen, I use a full screen shortcut : Control + Spacebar (on Mac)
Fullscreen without the mac osx menubar would be great ( autohide )
phathak2002
Community Visitor
Community Visitor
What if this shortcut doesn't work? It worked yesterday but refuse to work today. I'm stuck in the full screen mode... I suppose I need to reset preferences?
You can remove the menu bar by adding
<key>LSUIPresentationMode</key>
<integer>4</integer>
to /Applications/Autodesk/maya2011/Maya.app/Contents/Info.plist
mspeer
There is a fullscreen mode in Maya!
Just turn off "Show menubar" in preferences->Interface.
http://download.autodesk.com/us/maya/2011help/files/Basics_Windows_and_Editors_Interface_preferences...
mahmoud_azab
if you want to create a fullscreen mode, "just like toxik" --and i think there are no direct shortcut for that, u can do it using this code:
window -e -titleBar 0 $gMainWindow;
you can back to ur default maya "normal view with the titlebar"; use the same code, BUT:
window -e -titleBar 1 $gMainWindow;
or you can check the box in prefrences > interface [] show title bar in main window..
u can create a shelf button to toggle the operation above..
plus,
- to hide the maya main menus hit < CTRL + m >
- to hide the viewport menu press < SHIF + m >
- CTRL + spacebar but, you need first to point the mouse pointer on the view port then hit (ctrl + space)
** now the next shortcut is completely new in maya (2011):
if you have a lot of nodes in ur scene and you want to select one of them rapidly you can view them like a menu of nodes using this simple trick:
in the attribute Editor you will notice that ur nodes are listed as a tabs, and there are to arrows to scroll ur nodes , NOW DO THIS:
while scrolling --keep ur left-mouse-button on.. then press the right-mouse-button (both at the same time).. u will see then the whole list of used nodes as a menu..
nice day 🙂
Mahmoud alazab
mspeer
For Mac users it seems to be easy:
from online help (link again: http://download.autodesk.com/us/maya/2011help/files/Basics_Windows_and_Editors_Interface_preferences... 😞
To hide or display the main menu bar of Maya on Mac OS X, press the asterisk button (*) three times.
phibonacciSequence
If anyone is still interesting in his feature, I've added a request in the Maya Ideas forum:
https://forums.autodesk.com/t5/maya-ideas/fullscreen-mode-for-pc/idc-p/10430028#M3839
I'm hoping to gather support.
