Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Folder "Autdesk" was created outside the "Program Files".
5 REPLIES 5
nemias.barbosa
350 Views, 5 Replies
Hello everyone, I have some versions of maya installed, but after installation a folder called "Autdesk" was created outside the "Program Files" folders with all versions, these folders have the end "_dlm", these folders after installation can they be erased without impairing the functioning of the maya?
Tags (1)
Labels (1)
5 REPLIES 5
You must be talking about DownLoad Manager.. take a look here on how to uninstall it https://knowledge.autodesk.com/search-result/caas/CloudHelp/cloudhelp/2016/ENU/Autodesk-Installation...
,,,_°(O__O)°_,,,
Maya2019.1 @ Windows10 & GeForce GTX1080Ti
If the post was helpful, click the
 ACCEPT SOLUTION  button, so others might find it much more easily.
Anifex09
in reply to: nemias.barbosa
Don't worry this folder just contains the installation files used to install Autodesk Products you can delete the folder after you installed your program at anytime.
nemias.barbosa
in reply to: Anifex09
Some programs use these folders to fix bugs without having to reinstall the program again, these folders have this function or can you delete it ?!
nemias.barbosa
Why won't you install all present bugfixes/updates for your version? Since you want to get rid of those folders, you can postpone uninstalling the DLM after you have worked in Maya for a week or so, when see no bugs that would require reinstall.
,,,_°(O__O)°_,,,
