Announcements
Fill Object not working
corvidstudios
corvidstudios
Hello, I am having troubles filling a lava lamp with a water particle. When I press "Fill Object" the water seems to be bound by the walls and bottom of the object but not the top. The lamp is not double walled and the object is fully sealed along with the passive collider active. undefined
Replies (11)
pshwayka
Just so we're on the same page - did you assign the passive collider node from the nCloth menu?
corvidstudios
Yes I used passive collider from the ncloth menu.
pshwayka
Okay...just making sure. Anyway, I just made a basic polygon cylinder, set it up as a passive collider, and did a "fill object" using water particles, and it seemed to contain the particles correctly.
If you hit the play button and animate the scene, do you get any warnings about particle size?
corvidstudios
Well the lamp does contain the particles properly. When I press play there is no error message, the particles that start inside of the lamp stay in and the particles outside the lamp drop down past the grid, resulting in a huge particle box that increases in size as the scene plays on
pshwayka
If you zip the scene and upload it, I'd be happy to take a look at it. (No problem if you don't want to.)
corvidstudios
I'll be able to tomorrow morning I'm at work right now, sorry about that
pshwayka
No problem. That actually works better for me, too!
corvidstudios
Okay here's the file, best of luck to you!
Andrew
pshwayka
Okay...I figured it out. Somehow you ended up with an extra shape node for the lamp object, so do this:
  1. Delete nParticle1, nucleus1, and nRigid1.
  2. Select lamp1 and click Windows->Node Editor
  3. Select the polySurfaceShape1 node and delete it. Close the node editor.
  4. Make lamp1 a Passive Collider, and do the nParticles->Fill object command.
  5. By the way, you have a ring of orphaned vertices partway up the lamp...if you go into vertex mode, you can select them and hit "delete."
  6. You should now have something that looks like the picture below. Give me a yell if you have questions.
undefined
corvidstudios
Thank you very much! It's working perfectly now. I have not had a person give me a more in depth and accurate solution than you so a big thumbs up and very much appreciated!
pshwayka
You're very welcome. Happy to help!
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
