Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
File corrupted - "fatal error," help!
5 REPLIES 5
asherm94
414 Views, 5 Replies
I was working on a file the other night. I saved the file but had it minimized overnight and unfortunately my computer crashed the next morning when I tried to turn it on. The computer is fine now but I can no longer open the file. Every time I do it loads, displays the scene and then I get a "fatal error" and the program crashes before I can interact with the file in any way. Can someone help me please?
I'm running Maya 2019 on Windows 10
I've attached the file in question, thanks!
Tags (2)
Labels (3)
5 REPLIES 5
asherm94
in reply to: asherm94
if it helps, I used a MASH node but I'm certain that I deleted the history so it shouldn't still be an issue, presumably. I do still see it in the Outliner, though.
mspeer
Hi!
I am not sure what exactly was the problem in this scene, but the crash was related to MASH, so I removed it from the scene.
Recovered scene attached.
asherm94
That worked, thank you! How did you remove the MASH? I couldn't even interact with the scene before it crashed every time
mspeer
Hi!
When crashing Maya saved a .ma version of the scene in the user temp folder that could be edited.
asherm94
in reply to: mspeer
Good to know. Thanks again!
