Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
FBX Dialog grows larger each time I export
1 REPLY 1
jake_black
165 Views, 1 Reply
Issue started since updating to Maya 2022.2 around August.
Every time that I export using the FBX format, the dialog pops up and is larger than the last time I exported. Eventually it is larger than my monitor and I need to scale it down to fit. I can scale it as small is it will go, so that only the "Export" and "Close" buttons are visible, after 4-5 additional exports it is larger than my monitor again.
1 REPLY 1
trs_andre
in reply to: jake_black
@jake_black
Hi!
Have you found a solution to this problem?
In my case it is not on the "export" dialog, but the "open" one.
I call it in a script I made, and each time the dialogs gets bigger...
André Moreira
Game Developer / Technical Artist
LinkedIn
