Fatal Error when trying to start Maya
I have just installed Maya2022 and I am running into this problem when trying to start it up. The loading bar gets to "Loading plugins (mayaUsdPlugin)", a pop up then appears saying there is a fatal error. I have attached a picture.
Any help to get maya up and running would be hugely appreciated.
Cheers Osten
  • Maya
patrick.schock
Autodesk Support
Autodesk Support
Hi @Anonymous,
are you trying to load a file when starting Maya 2022? If so, please try to start Maya 2022 without loading a file and see if it works.
If the fatal error persists when launching the program without loading a file, you can proceed with these first (basic) steps:
  1. Close Maya and follow the steps from here: How to reset the Maya Preferences to Defaults.
  2. Check if the drivers of your graphic card are up to date: How to update to the latest certified video driver for Autodesk software.
  3. If Maya still does not start, follow the instructions from here: Perform a clean uninstall.
I hope you will have success. Please reply if you need further troubleshooting steps.
Best regards,
Patrick
“https://damassets.autodesk.net/content/dam/autodesk/logos/autodesk-logo-primary-rgb-black-small_forum.png”
