AREA content is being relocated to the Autodesk Community M&E Hub and Gallery. Notifications may be intermittently unavailable 10–12 November. Learn more HERE.
Fatal error attempting to save in maya 2018
Message 1 of 12
I am using the student version, suddenly while I am working, after up to 1 to 5 minutes the message “fatal error attempting to save in C:...” shows.
My specs are
Windows 7 Home premium
Intel(R) Core(TM) i7-4970K CPU @4.00GHz
RAM 16GB
64bit
NVIDIA GeForce GTX 960
Replies (11)
Message 2 of 12
My specs are
RAM 16GB
64bit
Message 3 of 12
My specs are
RAM 16GB
64bit
Message 4 of 12
My specs are
RAM 16GB
64bit
Message 5 of 12
sean.heasley
Hi @Anonymous
What happens when the crash occurs? Are you modeling, animating etc? Is there any steps to reproduce the crash?
Also, when the crash occurs, does Maya generate an error report for you to fill out and submit to Autodesk? If so, please fill it out and let me know what the CER report number is.
Please let me know if anything changes!
Message 6 of 12
This is happening when I am animating, more specific just posing the character I have just created the reference and start to pose it. So this happens when I am moving controls.
Now I tried to rollback the graphic card driver and maya just crashed without any error
Message 7 of 12
While I am animating this is what comes up when maya crashes: (file attached)
Message 8 of 12
sean.heasley
Hi @Anonymous
It looks like it does generate an error report but I need to know the CER number that is generated. Once you fill out the report and hit submit it should open your browser and say CER_          with a number, please let me know what that number is.
Also, your file was probably too large to attach to to the forum post manually. When you get a chance, can you please zip and attach the scene file here or via dropbox/google drive or another file sharing program so I can take a look at it?
Message 9 of 12
Hello Sean,
 CER_189254241
here thereis the folder with the screenshots :  https://we.tl/t-l8SUTJm1yq
Message 10 of 12
sean.heasley
Hi @Anonymous
Thanks for posting the CER number! It looks like this may be related to a known issue with 2018 that a fix is currently being worked on. You could try this in 2019 to see if the same issue occurs.
Also, I don't need the screenshots I need the actual scene file in order to test and confirm this issue.
Message 11 of 12
sean.heasley
Hi @Anonymous
Just wanted to check in to see how things were going. Are you still having this issue? If so please send me the scene file.
If your issue is resolved, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Message 12 of 12
Thank you for your help, now with maya 2019  it works fine 🙂 I haven’t had that problem anymore. apparently I had this problem from maya 2016 to 2018
thanks
Federica
