Fatal Error. Attempting to save in C:/Users/User/AppData/Local/Temp/User.2020062
HI,
I am unable to open Maya 2020 and whenever I try to open I get this message
Fatal Error. Attempting to save in C:/Users/User/AppData/Local/Temp/User.20200626.2220.ma
I fully uninstalled and re-installed Maya but still getting the same message.
I am a new beginner in learning Maya.pls.help.
warnold2
Additional information would be helpful to suggest what might be the problem
Operating System (OS)
hardware configuration, graphics card
any related files written to the TEMP directory
was there a CER diagnostics dialog to send in,  if so, the CER number
there are a number of reasons for launch issues Including; hardware / software / driver configuration
don’t run as administrator
Maya preference files may have issues if from different versions
  move aside your current preference directory
Mismatched OpenCL drivers are known to cause startup problems
 ensure you have latest drivers installed,
 To test: can set environment variable MAYA_DISABLE_OPENCL=1 before launching maya from a CMD window, if this works can dig into settings that may resolve
local Python modules that override / conflict with those within the Maya installation can cause conflicts
Wayne Arnold
Developer
Windows 10
NVDIA Gforce GTX 1070 32 GB Memory
(no idea as I am new to Maya)
I tried all options but not use
(for this do I have to go inside Maya? the problem is
in Launching Maya itself it crashes and  hence unable to access any adjustments
inside Maya)
(no idea how this is to be done) can you please specify?
(no idea)
Any solution suggestion for my Maya issue that I posted?
thanks
anyone out there to help me to sort this problem?
alec.andersenLP8AU
Hi @Anonymous,
If you're unable to open Maya 2020 I would suggest resetting your preferences. If that doesn't work, I'd suggest a clean uninstall, and then try giving it another download! The error you're seeing is a pretty "generic" one; basically there are a lot of different issues that can cause this, hence why I'm suggesting the basics.
You can follow these guides to help you along!
Reset your Maya preferences | Maya 2019 | Autodesk Knowledge Network
Perform a clean uninstall | Download & Install | Autodesk Knowledge Network
Thank you. I deleted my preference settings and now it is working perfectly
Thank you
