Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Fatal crash every time I try to render in any way. Please help!
1 REPLY 1
pizwiz
547 Views, 1 Reply
I get an error any time I try to render anything in Maya. I will post the crash report on the bottom.
I've reinstalled Maya, but there it's still happening.
Maya Crash Report
Exception code: C0000005: ACCESS_VIOLATION - illegal write at address 0x321102C8
Fault address:  C3A1FAAD in C:\Windows\SYSTEM32\ntdll.dll
0001:0002EAAD Logical offset (see .map file for location)
Call stack:
	Module:  C:\Program Files\Autodesk\Maya2022\bin\Foundation.dll (-exported-)
	Location: Foundation.dllTmallocAllocator::printStatistics + 30C bytes
	Decl: public: void __cdecl TmallocAllocator::printStatistics(class std::basic_ostream<char,struct std::char_traits<char> > & __ptr64) __ptr64
	Module:  C:\Program Files\Autodesk\Maya2022\bin\RenderSlice.dll (-exported-)
	Location: RenderSlice.dllTrenderFrame::cleanUp + 109 bytes
	Decl: public: int __cdecl TrenderFrame::cleanUp(bool) __ptr64
	Location: RenderSlice.dllTrenderFrame::render + E56 bytes
	Decl: public: int __cdecl TrenderFrame::render(class TrenderCamera & __ptr64,class TgeoManager * __ptr64,class Trect & __ptr64,bool,class Trect & __ptr64,class Tstring & __ptr64,class Tstring & __ptr64,class Tstring & __ptr64,class Tstring & __ptr64,bool,bool,
	Location: RenderSlice.dllTrenderTileExtent::imageOriginY + 324C bytes
	Decl: public: int __cdecl TrenderTileExtent::imageOriginY(void)const __ptr64
	Location: RenderSlice.dllTrenderItemCmd::doIt + 3B bytes
	Decl: public: bool __cdecl TrenderItemCmd::doIt(void) __ptr64
	Location: RenderSlice.dllTrenderAction::doCommand + 4F9 bytes
	Decl: public: virtual bool __cdecl TrenderAction::doCommand(class TargList & __ptr64) __ptr64
	Module:  C:\Program Files\Autodesk\Maya2022\bin3\CommandEngine.dll (-exported-)
	Location: CommandEngine.dllTjournal::operator= + 4F6 bytes
	Decl: public: class Tjournal & __ptr64 __cdecl Tjournal::operator=(class Tjournal const & __ptr64) __ptr64
	Location: CommandEngine.dllSophiaExecutable::evaluate + 47 bytes
	Decl: public: union Value * __ptr64 __cdecl SophiaExecutable::evaluate(void * __ptr64) __ptr64
	Location: CommandEngine.dllTcommandEngine::executeCommand + A6 bytes
	Decl: public: int __cdecl TcommandEngine::executeCommand(class SophiaExecutable * __ptr64) __ptr64
	Module:  C:\Program Files\Autodesk\Maya2022\bin3\ExtensionLayer.dll (-exported-)
	Location: ExtensionLayer.dllTrepeatCommandManager::getCommandString + 1C33 bytes
	Decl: public: void __cdecl TrepeatCommandManager::getCommandString(short,class Tstring & __ptr64) __ptr64
	Location: CommandEngine.dllsetMelGlobalStackLevelPtr + 728 bytes
	Decl: void __cdecl setMelGlobalStackLevelPtr(unsigned int (__cdecl*)(void))
	Location: CommandEngine.dllsetMelGlobalStackLevelPtr + 31 bytes
	Location: CommandEngine.dllsetMelGlobalStackLevelPtr + 1B49 bytes
	Location: CommandEngine.dllsetMelGlobalStackLevelPtr + 1663 bytes
	Location: CommandEngine.dllTcommandEngine::executeCommand + 3FC bytes
	Decl: public: int __cdecl TcommandEngine::executeCommand(class Tstring const & __ptr64,bool,bool,class TmelCmdResult * __ptr64,unsigned int) __ptr64
	Location: ExtensionLayer.dllTscriptActionMixin::execute + 1A3 bytes
	Decl: protected: bool __cdecl TscriptActionMixin::execute(class Tevent const & __ptr64,class std::unique_ptr<class TinterpreterResult,struct std::default_delete<class TinterpreterResult> > * __ptr64) __ptr64
	Location: ExtensionLayer.dllQmayaQtHelper::executeCommandScript + 8F bytes
	Decl: public: static bool __cdecl QmayaQtHelper::executeCommandScript(char const * __ptr64,class QObject * __ptr64)
	Location: ExtensionLayer.dllQmayaIconTextButton::mouseReleaseEvent + 257 bytes
	Decl: protected: virtual void __cdecl QmayaIconTextButton::mouseReleaseEvent(class QMouseEvent * __ptr64) __ptr64
	Module:  C:\Program Files\Autodesk\Maya2022\bin\Qt5Widgets.dll (-exported-)
	Decl: protected: virtual bool __cdecl QWidget::event(class QEvent * __ptr64) __ptr64
	Location: Qt5Widgets.dllQApplicationPrivate::notify_helper + 110 bytes
	Decl: public: bool __cdecl QApplicationPrivate::notify_helper(class QObject * __ptr64,class QEvent * __ptr64) __ptr64
	Location: Qt5Widgets.dllQApplication::notify + 750 bytes
	Decl: public: virtual bool __cdecl QApplication::notify(class QObject * __ptr64,class QEvent * __ptr64) __ptr64
	Location: ExtensionLayer.dllQmayaApplication::currentMousePos + 80F bytes
	Decl: public: static class QPoint __cdecl QmayaApplication::currentMousePos(void)
	Module:  C:\Program Files\Autodesk\Maya2022\bin\Qt5Core.dll (-exported-)
	Location: Qt5Core.dllQCoreApplication::notifyInternal2 + BA bytes
	Decl: private: static bool __cdecl QCoreApplication::notifyInternal2(class QObject * __ptr64,class QEvent * __ptr64)
	Location: Qt5Widgets.dllQApplicationPrivate::sendMouseEvent + 3C5 bytes
	Decl: public: static bool __cdecl QApplicationPrivate::sendMouseEvent(class QWidget * __ptr64,class QMouseEvent * __ptr64,class QWidget * __ptr64,class QWidget * __ptr64,class QWidget * __ptr64 * __ptr64,class QPointer<class QWidget> & __ptr64,bool,bool)
	Location: Qt5Widgets.dllQSizePolicy::QSizePolicy + 2D3A bytes
	Decl: public: __cdecl QSizePolicy::QSizePolicy(void) __ptr64
	Location: Qt5Widgets.dllQSizePolicy::QSizePolicy + CBE bytes
	Location: Qt5Widgets.dllQApplication::notify + 18B3 bytes
	Module:  C:\Program Files\Autodesk\Maya2022\bin\Qt5Gui.dll (-exported-)
	Location: Qt5Gui.dllQGuiApplicationPrivate::processMouseEvent + 936 bytes
	Decl: public: static void __cdecl QGuiApplicationPrivate::processMouseEvent(class QWindowSystemInterfacePrivate::MouseEvent * __ptr64)
	Location: Qt5Gui.dllQWindowSystemInterface::sendWindowSystemEvents + 90 bytes
	Decl: public: static bool __cdecl QWindowSystemInterface::sendWindowSystemEvents(class QFlags<enum QEventLoop::ProcessEventsFlag>)
	Location: Qt5Core.dllQEventDispatcherWin32::processEvents + 6A bytes
	Decl: public: virtual bool __cdecl QEventDispatcherWin32::processEvents(class QFlags<enum QEventLoop::ProcessEventsFlag>) __ptr64
	Module:  C:\Program Files\Autodesk\Maya2022\plugins\platforms\qwindows.dll (-exported-)
	Location: qwindows.dllqt_plugin_query_metadata + 1F99 bytes
	Decl: public: int __cdecl QEventLoop::exec(class QFlags<enum QEventLoop::ProcessEventsFlag>) __ptr64
	Location: Qt5Core.dllQCoreApplication::exec + 154 bytes
	Decl: public: static int __cdecl QCoreApplication::exec(void)
	Location: ExtensionLayer.dllTapplication::start + E5 bytes
	Decl: public: void __cdecl Tapplication::start(void) __ptr64
	Module:  C:\Program Files\Autodesk\Maya2022\bin\mayaLib.dll (-exported-)
	Location: mayaLib.dllTiteratorWrapperFwd<TscenePartitions::ConstIteratorDescriptor,TiteratorWrapper<TscenePartitions::ConstIteratorDescriptor> >::operator++ + 11B2 bytes
	Decl: public: class TiteratorWrapper<struct TscenePartitions::ConstIteratorDescriptor> & __ptr64 __cdecl TiteratorWrapperFwd<struct TscenePartitions::ConstIteratorDescriptor,class TiteratorWrapper<struct TscenePartitions::ConstIteratorDescriptor> >::operator++
	Module:  C:\Program Files\Autodesk\Maya2022\bin\maya.exe (-nosymbols-)
	Decl:  ??
	Decl:  ??
	Module:  C:\Windows\System32\KERNEL32.DLL (-exported-)
	Module:  C:\Windows\SYSTEM32\ntdll.dll (-exported-)
End of stack
//crash log file name = C:\Users\pizwi\AppData\Local\Temp\MayaCrashLog210411.1950.log
//version     = 22.0.0.217
//cut            =  02/18/2021, 202102181415
//current scene = unDisclosed
//command history (most recent last):
//last tool: renderWindowSelectContextItem
//panel with focus: renderView
//visible panels:
// modelPanel4 renderView
//Memory usage:
// 9300.004 Mb	Free Memory
// 19917.789 Mb	Free Swap
// 1251.098 Mb	Current
Labels (4)
1 REPLY 1
patrick.schock
in reply to: pizwiz
Hello @pizwiz,
thanks for posting this issue. I would recommend the following steps:
  1. In case you didn't perform it, refresh the Maya preferences: How to reset the Maya Preferences to Default. This sounds boring, but is always the best start to exclude issues in the preferences.
  2. Test, if the crash remains.
  3. If yes, create a new Windows user to see if writing permissions are causing the issues: Create a local user or administrator account in Windows 10. Create the new user with Administrator rights.
  4. If the crash is still happening, update the driver of your graphic card and see if it meets the system requirements.
It may be required to proceed with different steps, depending on your technical environment. If the crashing behavior can't be solved by the steps above, please send me an NFO file of your computer configuration in a private message to investigate the next steps: How to obtain a System Information file (NFO) for diagnostics and troubleshooting.
Hope this is helpful for you!
Best regards,
Patrick
“https://damassets.autodesk.net/content/dam/autodesk/logos/autodesk-logo-primary-rgb-black-small_forum.png”
